How to save downloaded plug in on KDS
holyhope
Hi to all
Now I'm resetting KDS and I discovered that there is a plug in that is not still available (on an external repository)....
I'm installing several plug-in by off-line method (with "install new software" but point on a local path).
to avoid in future plug in will be not available.... There is a way to download, in local, one plugin now available on an external repository? So the next time, if it will be not available anymore, I can install that plug-in from my local path...
Many thanks
Tags (2)
BlackNight
BlackNight
Hi Massimiliano,
yes, there is a way:
http://mcuoneclipse.com/2014/07/03/replicating-an-eclipse-update-site-for-offline-usage/
I hope this helps,
Erich
holyhope
Him
Sorry for delay.
Many thanks, is what i was searching.
I prefer something more simple or automatic but this way had worked very wall.
Many thanks
Massimiliano
