How to reuse KL02 reset pin as GPIO
Search instead for
eve
How to reuse KL02 reset pin as GPIO?
nxf56274
要禁用reset功能在fopt寄存器里
fopt在
FLASH configuration在代码里位置
ErichS
Senior Contributor IV
In principle, you have to mux the pin as a GPIO pin and disable the reset functionality. Best if you consult the reference manual.
How to do this with Processor Expert or in general, see https://mcuoneclipse.com/2013/02/16/using-the-reset-button-on-the-freedom-board-as-user-button/ (using KL25, but KL02 is very similar).
I hope this helps,
Erich
PS: I recommend to use a 'safety line' and not remuxing the pin right after reset, otherwise you might have difficulties to access the device using a debugger.
