How to implement watchdog timer in Kinetis MK60FN1M0VLQ12 ?
1,139 次查看
rajkumar_yerraj
I need to implement watchdog for my application. With reference to datasheet/ref manual of Kinetis MK60FN1M0VLQ12, I understand that WDOG can be used for the same. The objective is to load a timer in case of any stuck or error due to some indefinite call of loop (mainly while) or any other segmentation faults, the timer configurable of any say 25 - 35 secs (maximum time take for a task) after that it shall try to clear or exit out of that or reset the entire system. The sw/application uses indefinite while loop and no OS. Can anyone suggest me how to proceed with implementation specific for Kinetis MK60FN1M0VLQ12.
Rajkumar
917 次查看
rajkumar_yerraj
Hi Alexis,
Thank you very much for the info.
It really helped me.
-Gangadhar
917 次查看
Alexis_A
Dear Gangadhar,
I will suggest to check the examples that came in the following example to check how to use the WDOG, you can found them under Code Snippets:
 Arm® Cortex®-M4|Kinetis K60 100 MHz 32-bit Microcontrollers|NXP | NXP
Also this thread has an example driver that could be useful to set the module.
K60 Watchdog Refresh Issue
Regarding the implementation, you could put the refresh function in a timer interruption (LPTMR for example).
Let me know if this helps you.
Alexis Andalon
