Get dt for numerical integration
1,187件の閲覧回数
aminesedki_as
I want to implement a complementary filter for IMU data fusion than i can't see how we can get the time delay after each data sampling this time will be used for gyroscope numerical integration (dt), i want to know also if there is a function in MCUXpresso API that could help me.
Thanks for you.
Sincerely.
4 返答(返信)
1,093件の閲覧回数
Alexis_A
Dear aminesedki.as@gmail.com‌,
 Could you let me know which MCU are you using?
Alexis Andalon
1,093件の閲覧回数
aminesedki_as
I use the a TWR-K60D100M which include a Kinetis K60 32-bit MCU.
Thanks for your quick reaction.
1,093件の閲覧回数
Alexis_A
Dear Amine,
If you only need certain delay between the sampling you could try using a timer to do it. Maybe the FlexTimer examples could help with it.
Also the using the PDB module could be a good option for it.
You can find examples for this two modules in the SDK.
I hope this helps you.
Alexis Andalon
1,093件の閲覧回数
aminesedki_as
Dear Alexis,
Thanks for your quick reaction, i will try this two modules.
Amine Sedki
