Generate a 1MHz timer with low power timer driver
359 次查看
Fayojimi
I have a KL03 board and I can generate a timer using the 1kHz LPO. However, I wanted to know if I can generate a 1MHz timer using a different clock as I am trying to interface with an HC-SR04 Ultrasound sensor.
343 次查看
nxf56274
LPTMR  has four clock source. MCGIRCLK,  LPO, ERCLK32K, OSCERCLK.
You can use MCGIRCLK to generate 1 Mhz.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
