Hi there.
FRDM-KW38 and MCUXpresso shows the message below.
Failed on connect: Ee(42). Could not connect to core.
No connection to chip's debug port
Do you know how to fix this problem?
Regards.
Shigeto
Could you please take a look to these threads? It seems that they had similar problems.
https://community.nxp.com/t5/MCUXpresso-General/FRDM-KW36-Wire-ACK-Fault-in-DAP-access/td-p/863513
I hope this helps, Daniel.
