FTFE Flash sector command always return ACCERR
jackylau
I'm using a Kinetis K61 (MK61FN1M0) and trying to use the FTFE module for boot loading.
I'm able to get Erase Sector and Program Phrase to work, but somehow I spend hours and still couldn't get Flash sector to work (always return ACCERR). I follow through Table 30-53 and verify that my parameters are correct - below is a section of the code that I'm using. I copied the data onto 0x14000000 (the programming acceleration RAM) and if I understand the reference manual correctly, I should be able to flash 4k byte at a time using the Program Sector command.
#define FLASH_PROGRAM_SECTOR 0x0B
#define PROGRAM_SECTOR_INDEX 0x06
LWord FLASH_ProgramSector(LWord destination, LWord size)
    /* destination must be 128-bit aligned */
    unsigned long NumOfDoublePhrase;
    /* double phrase align check */
    if (destination & 0x0F)
        return 0;
    NumOfDoublePhrase = size * 8 / 128;
    CommandObj.regsLong.fccob3210 = destination;
    CommandObj.regs.fccob0 = FLASH_PROGRAM_SECTOR;
    CommandObj.regs.fccob4 = (NumOfDoublePhrase & 0xFF00) >> 8;
    CommandObj.regs.fccob5 = NumOfDoublePhrase & 0x00FF;
    return FLASH_FlashCommandSequence(PROGRAM_SECTOR_INDEX);  /* always return ACCERR */
/* FLASH_FlashCommandSequenceStart cames from Freescale's Kinetis Serial Bootloader A2295 */
LWord FLASH_FlashCommandSequenceStart(Byte index)
  Byte* ptrFccobReg = (Byte*)&FLASH_BASE_PTR->FCCOB3;
  Byte* ptrCommandObj = (Byte*)&CommandObj;
  /* wait till CCIF bit is set */
  while(!(FLASH_FSTAT & FLASH_FSTAT_CCIF_MASK)){};
  /* clear RDCOLERR & ACCERR & FPVIOL flag in flash status register */
  FLASH_FSTAT = FLASH_FSTAT_ACCERR_MASK | FLASH_FSTAT_FPVIOL_MASK | FLASH_FSTAT_RDCOLERR_MASK;
  /* load FCCOB registers */
  while(index--)
    *ptrFccobReg++ = *ptrCommandObj++;
  /*  launch a command  */
  FLASH_FSTAT |= FLASH_FSTAT_CCIF_MASK;
  /*  waiting for the finishing of the command */
   /* Check error bits */
  /* Get flash status register value */
  return (FLASH_FSTAT & (FLASH_FSTAT_ACCERR_MASK | FLASH_FSTAT_FPVIOL_MASK | FLASH_FSTAT_MGSTAT0_MASK));
Thank you for your help!
Tags (3)
jeremyzhou
Two options:
1. You can use the FLASH_ProgramSectionByPhrases() fuction to program the Flash which is provided by AN2295 demo code too.
2. I'd also like to suggest that you can use use the C90TFS flash driver which include a quite of flash functions, and you can use these functions directly.
C90TFS flash driver:cache.freescale.com/files/32bit/software/C90TFS_FLASH_DRIVER.exe?fromsite=zh-Hans
Hope it helps.
Ping
