I am looking into making a shield for the K66 and was wondering if anybody has a mechanical drawing or even 3D model of the board. Other boards' design files include the Allegro .brd file, from which an accurate mechanical model could be derived, too.
For just the pin headers, I am aware that the mechanicals are the same as for the Arduino R3.
Philipp
Li,
The files that you're referring to do not contain the actual pcb file, Allegro tool from Cadence store their board files with extension .brd, while the files in the allegro\ directory are of type .dat Can you also attach the dxf/dwg output of the board, because Cadence Allegro viewer does not support export function.
