FRDM K64f failing launch sequence
609 次查看
smith1
I have two FRDM K64f boards, and I am trying to get CAN communication to work between them, and now one of my boards when I try to program it says that there is a failure in launch sequence. In order to program both boards, I was unplugging one of the boards, so I could program the other, which I think may have to led to this, but I'm not sure how to fix this issue.
Also, if you know how I could program both boards without unplugging one of them that would be helpful as well.
标记 (2)
526 次查看
BlackNight
Hi Timothy,
you have to specify different port numbers for each connection, see Debug Multiple Boards with GDB at the Same Time | MCU on Eclipse . Then you can debug multiple boards the same time.
I hope this helps,
Erich
526 次查看
smith1
I've fixed my issue by resetting the firmware on the board, but are there any suggestions on programming one of boards without unplugging the other?
526 次查看
kerryzhou
Hi Timothy Smith,
     You can try the Segger JLINK's method: multiple devices in the scan chain.
   More details, please refer to this document:
https://www.segger.com/admin/uploads/productDocs/UM08001_JLink.pdf
Page 180, chapter 5.3 JTAG interface.
Wish it helps you!
Kerry
