Does the NXP USB stack fot the Kinetis K6x support the SetFeature Test_mode request for test pattern generation?
519件の閲覧回数
mrharmonsr
I need to run an eye pattern test on a Kinetis board, but the SetFeature testmode request doesn't seem to work
ラベル(2)
425件の閲覧回数
danielchen
Hi Larry:
I assume you are testing this feature on device mode.
If yes, I would suggest you enable below macro and try it again.
/*! @brief Whether device compliance test is enabled. If the macro is enabled,
    the test mode and CV test macroes will be set.*/
#define USB_DEVICE_CONFIG_COMPLIANCE_TEST (0U)
change to
#define USB_DEVICE_CONFIG_COMPLIANCE_TEST (1U)
Have a nice day!
