Debouncing time in TSS3.1
679件の閲覧回数
sureshjaggal
Dear Folks,
I am using TSS3.1 in TSI configuration and KL05Z32 to develop a HMI application.
It is mentioned in the TSS application reference manual that the debouncing time  for the touch Input is taken care by the TSS library .
My questions are
1) How much is the debouncing time , that the TSS is configured with ?
2) How can we change the debouncing time for our requirements in TSS ?
Thanks & Regards,
Suresh Jaggal.
ラベル(2)
タグ(2)
599件の閲覧回数
vicentegomez
Hi Suresh
The debouncing rate is modified with the ResponseTime register that defines how many samples need to be valid before considering a measured value as valid. The feature is available in all key detector versions. Refer to the TSS reference manual - Number of samples register.
Depending your application maybe you need more or less samples for your application.
I hoe this will help you.
Vicente.
600件の閲覧回数
vicentegomez
Hi Suresh
Vicente.
