Could I set OSCERCLK as the PWM clock source in FTM moudle in FRDM-K64F?
Search instead for
gloria
Hi, could I set OSCERCLK as the PWM clock source in FTM moudle in FRDM-K64F? If yes, how could I do it? Many thanks!
mjbcswitzerland
Specialist V
The FTM (used for PWM) can be optionally clocked from the MCGFFCLK but not directly from OSCERCLK.
See µTasker MCG Configuration Support
Depending on the configuration of the MCG ,MCGFFCLK may be related to OSCERCLK (or derived from it) but it is highly unlikely that it will be the same frequency.
Mark
Kinetis: µTasker Kinetis support
K64: µTasker Kinetis FRDM-K64F support  / µTasker Kinetis TWR-K64F120M support  / µTasker Kinetis TWR-K65F180M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
