Cavalier treatment of status returns in 5.0 Usb_Composite_Requests() in usb_composite.c
1,197件の閲覧回数
johnstrohm
In the Freescale 5.0 Beta USB stack, in file usb_composite.c, in routine Usb_Composite_Requests(), the following lines appear (line numbers added for convenience):
456:                    USB_HID_Requests(setup_packet,data,size,(void *)devicePtr->hid_handle);
468:                USB_Audio_Requests(setup_packet,data,size,(void *)devicePtr->audio_handle);
478:                        status = USB_CDC_Other_Requests(setup_packet,data,size, (void *)devicePtr->cdc_handle);
490:                        status = USB_MSC_Requests(setup_packet,data,size, (void *)devicePtr->msc_handle);
504:                    USB_PHDC_Requests(setup_packet,data,size,(void *)devicePtr->phdc_handle);
USB_HID_Requests() returns a status.
USB_Audio_Requests() returns a status.  (Also, usb_audio.c contains a prototype for Usb_Audio_Other_Requests().  That should probably change to Usb_Audio_Requests().)
USB_PHDC_Requests() returns a status.
All of them may return error status, not just USB_OK.
The lines should probably be changed to:
456:                    status = USB_HID_Requests(setup_packet,data,size,(void *)devicePtr->hid_handle);
468:                status = USB_Audio_Requests(setup_packet,data,size,(void *)devicePtr->audio_handle);
504:                    status = USB_PHDC_Requests(setup_packet,data,size,(void *)devicePtr->phdc_handle);
ラベル(2)
タグ(2)
1,040件の閲覧回数
Kan_Li
Hi John,
Thanks for the report! I have forwarded your suggestion to our USB stack team and they will fix it in the future. I will update when I have any more information.
Thanks again and Best Regards,
Kan
