Can MKE14F512VLL16 support Quad SPI
Search instead for
prathamesh_h_patil
Can I interface Quad SPI to MKE14F512VLL16 controller as it support LPSPI and How we can interface it please explain in details.
jingpan
Hi @prathamesh_h_patil ,
Yes, LPSPI can support QUAD SPI flash. You can refer to this link
https://community.nxp.com/t5/i-MX-RT/LPSPI-how-to-set-for-QSPI-flash-device/m-p/1177734
Unfortunately, we don't have any example of the LPSPI interfacing an external flash.
Jing
prathamesh_h_patil
Thanks For confirmation.
Can you please share its QPSI frequency?
and what it support Like Single Data Rate (SDR) or Double Data Rate  (DDR)?
jingpan
Please see table 56 in datasheet. Frequency of operation can be max to fperiph/2.The max fperiph is from SPLLDIV2. So, max frequency is 168/2/2=42Mhz.
LPSPI doesn't support DDR.
Jing
prathamesh_h_patil
Thanks for information,
Q1. Could you please share Application note for Quad SPI for Flash memory?
Q2. Does MKE14F512VLL16 controller has restriction on particular make Quad Flash memory should use or it is free for any make quad flash?
Q3. Can MKE14F512VLL16 support SPI based Graphical LCD? if yes please share example.
jingpan
A1. No, there isn't.
A2. I think it is free for any QSPI flash.
A3. Yes, it can. But there isn't example.
prathamesh_h_patil
Dear NXP team,
As per the MKE14F512VLL16 datasheet supply voltage is 2.7V to 5.5V, so the question is if we use 3.3V as supply then is it okay for all operations, or else do we need to connect the 5V power supply.
Kindly check and suggest which supply is better for controller performance 3.3V or 5V?
jingpan
Either 3.3v or 5v is okey. You can freely determine VDD according to peripheral circuit. There is no difference in performance.
Jing
prathamesh_h_patil
Dear NXP team,
If my supply of the controller is 3.3V then can I connect the 5V peripheral signal to controller and Vice versa?
Please confirm it.
Prathamesh Patil
jingpan
No, you'd better don't design like that.
Jing
