Can I share bootloaders between MCUs?
1,063件の閲覧回数
derekcook
Senior Contributor I
Is it possible to use a bootloader developed for the KV31 with the KV56?
5 返答(返信)
1,021件の閲覧回数
derekcook
I see RAM is at 0x0000 to 0x10000. Is this fixed? If so I guess my bootloader must be from 0x10000000 to 0x1000a000 and my application can start at 0x1000a000
983件の閲覧回数
EdwinHz
Hi @derekcook!
You are correct. The RAM address is fixed, but the code address starts at 0x1000_0000. Table 5-1 of the datasheet shows the Memory Map:
BR,
Edwin.
1,022件の閲覧回数
derekcook
I am following this document to port the KV58F220M bootloader to the KV56. https://www.nxp.com/docs/en/reference-manual/MCUBOOTRM.pdf
With the KV31 we had our bootloader load to flash at 0xA000. We can still load to the same flash location with KV56? I noticed the default location was 0x1000a000.
1,023件の閲覧回数
derekcook
It looks like there is not a MCUBOOT specifically for the MKV56F512xxx24. However, there is a bootloader for the KV58F220M. I assume that's because this same bootloader works with the MKV56?
1,030件の閲覧回数
EdwinHz
Hi @derekcook
I’m afraid this isn’t possible.
Even though they are both MCUs from the same series, the differences between these two MCUs wouldn’t allow them to share bootloaders.
BR,
Edwin.
