I am new to freescale and am trying to initialize GPIO pins . Has any one tried or have documents on how to READ and WRITE on to an EEPROM by bit banging method ?
using KL05, atmel's 512kb EEPROM ,writing a C program to read and write data using bit banging( not via I2c module)
i need info on how to configure GPIO or FGPIO pins to do this.
Acknowledge polling is the major concerns ... how do i do it?
Solved! Go to Solution.
Hi Pradyumna,
yes. Here is a tutorial:
Using Keil µVision (ARM-MDK) with Processor Expert Driver Suite | MCU on Eclipse
I hope this helps.
yes, I'm using I2C bit banging to external EEPROM modules:
Bit Banging I2C | MCU on Eclipse
It features as well Processor Expert components for the 24AA external EEPROM modules (see losing my mind over i2c interfacing to 24lc00 eeprom).
Hello Erich ,
thank you so much for replying... i'm actually writing code in Kiel. will have to write my whole code again
will try and go through your component n use it ...
Thank you
Hi Pradyumna,
Keil supports Processor Expert, so no need to re-write that code.
0_0 really? thats cool .. how should i start then??
pls help how n from where shall i start
Hi Pradyumna,
I hope this helps.
If you need a software code to realise GPIO pin to simulate I2C communication?
B.R.
Ma Hui
Hello Ma Hui,
yes i need a code to make GPIO pins Simulate I2C communication... I need to communicate with an EEPROM.
failed miserably in writing the code as SDA pin of the EEPROM doesnt go low after sending the device address
some help will be really appreciated
Thank you
