Adding keil support for KINETIS_SC
My customer wanted to use K60 in his design but he only has the Keil IDE, so I helped to port some examples in KINETIS_SC for him as a starting point. The attachment is my porting work, which also includes a exe file to create new keil project. You may refer to "keil\build\uv4\make_new_project_keil.exe" for details.
Hope that helps,
B.R
Kan
Tags (2)
Comments
thanks very much.
No ratings
Version history
Last update:
‎10-11-2013 12:47 AM
Updated by:
