ADC value when input is less than 0V
407件の閲覧回数
williamely
In my design I have an ADC single ended input that may experience a voltage as low as -0.1V with respect to the analog Vss. I need to know what the conversion result will be in this case.
Is it 0?
Is it undefined?
ラベル(2)
299件の閲覧回数
jeremyzhou
Hi William Ely,
It will read 0 when -0.1V connect the input pin if VSS is 0V, however I'd highly recommend that the range of the analog input voltage should within Vrefl~Vrefh.
Hope it helps.
Ping
300件の閲覧回数
jeremyzhou
Hi William Ely,
Hope it helps.
Ping
