ADC on MK11
ADC on MK11
eduardrazumovsk
Is there anything unique with pins ADC0_DP0, ADC0_DM0, ADC0_DP3, ADC0_DM3 ?
Is it only ADC input pins (not GPIOs) ?
Can i use those pins exactly as i meant to use the ADC0_SEx pins ?
Thanks & Regards,
Eduard
Hello Eduard,
Do you want to know how to configure the pin to ADC functions ?
If yes ,  you can see the reference manual: 10.3.1 K11 Signal Multiplexing and Pin Assignments ,
we can see ,  these pins "ADC0_DP0, ADC0_DM0, ADC0_DP3, ADC0_DM3" can directly be used to ADC, for these pin only have ADC function.
While , for the ADC0_SEx pins , they are multiple function , if we want to use these pin to ADC , we need configure them through  "Pin Control Register n (PORTx_PCRn) "
If i misunderstand your meaning , can you be more specific !
Alice
If this post answers your question, please click the Correct Answer button.
If this post help your question, please click the helpful Answer button.
Hello Eduard,
Alice
eduardrazumovsk
Thanks Alice
