ADC Speed
776件の閲覧回数
lothar
Hi there
I' m using a tower modul with a K20 72MHz MCU and i would like to use the ADC.
I've got the following questions:
CFG2[ADHSC] is used to configure a higher clock input frequency. This will allow
faster overall conversion times. To meet internal ADC timing requirements,
CFG2[ADHSC] adds additional ADCK cycles. Conversions with CFG2[ADHSC]=1 take
two more ADCK cycles. CFG2[ADHSC] must be used when the ADCLK exceeds the
limit for CFG2[ADHSC]=0.
From which ADCK upwards it must be set? I didnt found that in the manual
After a reset what is the normal clock speed of everything?
Something like that:
Option 2:
Clock Frequency
Core clock 72 MHz
System clock 72 MHz
Bus clock 36 MHz
FlexBus clock 36 MHz
Flash clock 24 MHz
Am I right with that? Thanks in advance for your answer.
best regards
Lothar
413件の閲覧回数
apanecatl
Senior Contributor II
Hi Lothar
After a POR, all the mcu modules will be clocked at a 20.1 MHz frequency, which is predetermined, once the mcu initializes your code it will set up the modules to the CLK frequency you configured.
Regarding ADCK, it has two ranges:
≤ 13 bit modes    1 MHz < ADCK < 18 MHz
16 bit modes       2 MHz < ADCK < 12 MHz
Depending which resolution you use it is the ADCK range you can work with.
414件の閲覧回数
apanecatl
Hi Lothar
413件の閲覧回数
lothar
Thanks for your answer
In my case the clock is somehow set without doing anything. I guess there is a function start() which is called by default and it sets the OUTDIV1-4 Registers and some other stuff. It makes it like that:
Core clock 72 MHz          OUTDIV1 = 0
System clock 72 MHz      OUTDIV1 = 0
Bus clock 36 MHz            OUTDIV2 = 1
FlexBus clock 36 MHz      OUTDIV3 = 1
Flash clock 24 MHz          OUTDIV4 = 2
The second information about the ADCK is very useful. But where have you found that?
I searched in the Datasheet and in Cookbook for SAR ADC Measurements.
