set enumeration size
619件の閲覧回数
barbercolman
KDS will will create a 8 or 16 bit value based on the number of elements is an enumeration. This is great for optimization but causes issues where a fixed size is expected. We worked around this issue by setting an element to 65535. But it is not clean. Is there a way to force enums to UInt16 in KDS?
382件の閲覧回数
BlackNight
Hi Dale,
this is actually not a question about KDS, this is a question about compilers (well, gcc).
There is a good article about this topic:
http://stackoverflow.com/questions/1113855/is-the-sizeofenum-sizeofint-always
and you will find more if you search the internet e.g. for
gnu gcc force enum size
Some compilers have options to set the size. To my knowledge in gcc you only can set an option to pack (or making the enums 'short'), which is exactly what you do *not* want. So setting a dummy element with a value > one byte what I would do too. I don't see any other solution.
Erich
