rebuild toolchain for kinetis from scracth
742 次查看
mastupristi
Senior Contributor I
I need to rebuild whole kinetis toolchain from scratch.
I need to start from source code, applying patches, configure and build. In other words I need to replicate exactly the steps followed by Freescale to build toolchail delivered with KDS 3.0.0
Where can I find detailed instructions?
I mean: where to find source code, patches and other stuff? How to configure?
best regards
max
4 回复数
534 次查看
ZhangJennie
hello max
please log on NXP web site then go to this url
Kinetis Design Studio Integrated Development |NXP
then follow attached video to get the KDS 3.0 installer and all updates
can this help you?
Jennie Zhang
534 次查看
mastupristi
No, it doesn't help.
I have already downloaded and installed KDS 3.0.0.
I need to rebuild toolchain eg. for 64 bit systems, so the first step is to find source code and patches to apply, then configure and compile.
best regards
534 次查看
BlackNight
Hi Max,
KDS V3.0.0 uses stock launchpad (GCC ARM Embedded in Launchpad ) GNU build tools, without modifications. You should be able to re-build it yourself with the information and sources available from the Launchpad site.
I hope this helps,
Erich
534 次查看
pgo
Senior Contributor V
Hi Max,
I'm uncertain if this is what you are after but the toolchain included with KDS is a (I hope lightly) modified version of the Open source toolchain:
https://launchpad.net/gcc-arm-embedded
Source code and such is available via the above link.
bye
