ldr r0, =DefaultISR problem when used J-Link debug tool
872件の閲覧回数
jikanghu
When I used S32DS to start my design,  first i established a s32ds application project, the debugger tool which i chioced was segger J-Linker GDB server, after the project completed, it was build seccesfully, when i debuggered this project, it jumped to DefaultISR: ldr r0, =DefaultISR, the code showed below:
#include "derivative.h" /* include peripheral declarations SSKEAZ64M4 */
#include "gpio.h"
int main(void)
            CONFIG_PIN_AS_GPIO (GPIOB, PTG0, 1); // TLE7240_RST1_P48 Low active
            OUTPUT_SET(GPIOB, PTG0);
            #define COUNTER_LIMIT 100000
             int counter = 0;
            for(;;) {
                        counter++;
                        if(counter > COUNTER_LIMIT) {
                         counter = 0;
                         OUTPUT_TOGGLE(GPIOB, PTG0);
            return 0;
but when i choiced PE Micro GDB server, the same project had no such problem, what's the reason? thanks for replay.
573件の閲覧回数
Hello ,
Please share your whole project ,I will test it on my side .
If it is a private one , you can also submit a service request to attach it :
https://community.nxp.com/docs/DOC-329745
Alice
