debug_printf not printing floating point numbers
999件の閲覧回数
peter_fenn
In bare-metal KDS3 + KSDK1.2 project using debug_printf, all the remedial steps described in previous posts were tried but none of these fixed the issue.
Finally got float numbers to print correctly by uncommenting the #define PRINTF_FLOAT_ENABLE   1 in the print_scan.h file under the SDK\platform\utilities\src folder!
- What is the correct method (ie.from KDS IDE settings) to get this to work?
439件の閲覧回数
FeibiaoZhou
True. Other methods do not work to me and only Peter's method does. KDS3.0+KSDK1.3, MQX light.
439件の閲覧回数
DavidS
Hi Peter,
Check this post that towards the bottom shows how to add in #define in the Properties of the project.
If you try it let us know if this is successful or not.
printf() with float values
David
