Send strucuture using OSA_MsgQPut()
887 次查看
utsavikalpesh
Contributor V
I am working with KDS project and using processor expert mode. I am working with FreeRTOS.
In my case, I want to pass a structure rather than uint32_t data throughOSA_MsgQPut() , but when I am passing stucture, my program behaves wrong. My variable values are changing and due to this, program stucks.
When I pass only uint32_t data then, it works correctly.
Why this is so? I packed my structure, but not solved yet. I also study xQueueCreate() function, in my case it is message size is multiply by uint32_t, I write message size * (uint8_t) instead of message size * (uint32_t) but program stucks on defaultISR().
What to do? Please suggest.
Utsavi Bharuchwala
654 次查看
Hello Utsavi Bharuchwala,
Could you please share a simple project with the code "xQueueCreate()" that can reproduce your
problem, then I can check it on my side.
BTW, which chip do you used ?
Alice
654 次查看
utsavikalpesh
Contributor V
Hello Yang,
Thanks for reply. I am using MK60DN512VMD10.
Below are the small snippet.
Task1:
typedef struct
uint32_t data1;
void *ptr;
uint32_t data2;
uint32_t data3;
}Set_Struct;
Arr_Handler = OSA_MsgQCreate(&ArrayMsg, 20, sizeof(Set_Struct ));
Task2:
Set_Struct Structure; //define structure variable local
call_function_to_put_msg(&Structure); //call function which is put msg with structure pointer passed
Task3:
OSA_MsgQPut(ArrayMsg, &Structure);
In these case local variable of Task2 is changing. Why this is happening?
regards
Utsavi Bharuchwala
654 次查看
- Sorry I was wondering there is API like OSA_MsgQCreate() ?
FreeRTOS API categories
- There is FreeRTOS demo code under K60 in SDK package, I only test the function of xQueueCreate(),
it can work well .   You can download it from here : https://mcuxpresso.nxp.com/en/select
Alice
