SPI Flash and AT25HP512
656 次查看
briancavanagh
I'm using KDS 3.2.0, PE and the MK22FN256 uC.
In PE I'm using the component 'AT25HP512' to communicate with an external Flash IC (
AT25XE041B-XMHN-T).  Within PE I right-click and select "Help on Component" on AT25HP512 to determine how to use it but there's not much coding information available.
Can someone help me with this?  Perhaps there's a different component to use for the Flash IC I have on my circuit board.
Brian
343 次查看
ZhangJennie
I suppose that you are using the AT25HP512 component from the mcuoneclipse web pages. You can find all source code files on the git repository GitHub - ErichStyger/mcuoneclipse: McuOnEclipse Processor Expert components and example projects
If  you have question on this component, You can use the Issues · ErichStyger/mcuoneclipse · GitHub page and submit a new issue.
Jennie Zhang
