For example in MK22F51212.h in the GPIO Peripheral Access Layer section
/** GPIO - Register Layout Typedef */
typedef struct {
__IO uint32_t PDOR; /**< Port Data Output Register, offset: 0x0 */
__O uint32_t PSOR; /**< Port Set Output Register, offset: 0x4 */
__O uint32_t PCOR; /**< Port Clear Output Register, offset: 0x8 */
__O uint32_t PTOR; /**< Port Toggle Output Register, offset: 0xC */
__I uint32_t PDIR; /**< Port Data Input Register, offset: 0x10 */
__IO uint32_t PDDR; /**< Port Data Direction Register, offset: 0x14 */
} GPIO_Type, *GPIO_MemMapPtr;
-- GPIO - Register accessor macros
* @addtogroup GPIO_Register_Accessor_Macros GPIO - Register accessor macros
/* GPIO - Register accessors */
#define GPIO_PDOR_REG(base) ((base)->PDOR)
#define GPIO_PSOR_REG(base) ((base)->PSOR)
#define GPIO_PCOR_REG(base) ((base)->PCOR)
#define GPIO_PTOR_REG(base) ((base)->PTOR)
#define GPIO_PDIR_REG(base) ((base)->PDIR)
#define GPIO_PDDR_REG(base) ((base)->PDDR)
*/ /* end of group GPIO_Register_Accessor_Macros */
-- GPIO Register Masks
* @addtogroup GPIO_Register_Masks GPIO Register Masks
/* PDOR Bit Fields */
#define GPIO_PDOR_PDO_MASK 0xFFFFFFFFu
#define GPIO_PDOR_PDO_SHIFT 0
#define GPIO_PDOR_PDO_WIDTH 32
#define GPIO_PDOR_PDO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDOR_PDO_SHIFT))&GPIO_PDOR_PDO_MASK)
/* PSOR Bit Fields */
#define GPIO_PSOR_PTSO_MASK 0xFFFFFFFFu
#define GPIO_PSOR_PTSO_SHIFT 0
#define GPIO_PSOR_PTSO_WIDTH 32
#define GPIO_PSOR_PTSO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PSOR_PTSO_SHIFT))&GPIO_PSOR_PTSO_MASK)
/* PCOR Bit Fields */
#define GPIO_PCOR_PTCO_MASK 0xFFFFFFFFu
#define GPIO_PCOR_PTCO_SHIFT 0
#define GPIO_PCOR_PTCO_WIDTH 32
#define GPIO_PCOR_PTCO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PCOR_PTCO_SHIFT))&GPIO_PCOR_PTCO_MASK)
/* PTOR Bit Fields */
#define GPIO_PTOR_PTTO_MASK 0xFFFFFFFFu
#define GPIO_PTOR_PTTO_SHIFT 0
#define GPIO_PTOR_PTTO_WIDTH 32
#define GPIO_PTOR_PTTO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PTOR_PTTO_SHIFT))&GPIO_PTOR_PTTO_MASK)
/* PDIR Bit Fields */
#define GPIO_PDIR_PDI_MASK 0xFFFFFFFFu
#define GPIO_PDIR_PDI_SHIFT 0
#define GPIO_PDIR_PDI_WIDTH 32
#define GPIO_PDIR_PDI(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDIR_PDI_SHIFT))&GPIO_PDIR_PDI_MASK)
/* PDDR Bit Fields */
#define GPIO_PDDR_PDD_MASK 0xFFFFFFFFu
#define GPIO_PDDR_PDD_SHIFT 0
#define GPIO_PDDR_PDD_WIDTH 32
#define GPIO_PDDR_PDD(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDDR_PDD_SHIFT))&GPIO_PDDR_PDD_MASK)
*/ /* end of group GPIO_Register_Masks */
/* GPIO - Peripheral instance base addresses */
/** Peripheral PTA base address */
#define PTA_BASE (0x400FF000u)
/** Peripheral PTA base pointer */
#define PTA ((GPIO_Type *)PTA_BASE)
#define PTA_BASE_PTR (PTA)
/** Peripheral PTB base address */
#define PTB_BASE (0x400FF040u)
/** Peripheral PTB base pointer */
#define PTB ((GPIO_Type *)PTB_BASE)
#define PTB_BASE_PTR (PTB)
/** Peripheral PTC base address */
#define PTC_BASE (0x400FF080u)
/** Peripheral PTC base pointer */
#define PTC ((GPIO_Type *)PTC_BASE)
#define PTC_BASE_PTR (PTC)
/** Peripheral PTD base address */
#define PTD_BASE (0x400FF0C0u)
/** Peripheral PTD base pointer */
#define PTD ((GPIO_Type *)PTD_BASE)
#define PTD_BASE_PTR (PTD)
/** Peripheral PTE base address */
#define PTE_BASE (0x400FF100u)
/** Peripheral PTE base pointer */
#define PTE ((GPIO_Type *)PTE_BASE)
#define PTE_BASE_PTR (PTE)
/** Array initializer of GPIO peripheral base addresses */
#define GPIO_BASE_ADDRS { PTA_BASE, PTB_BASE, PTC_BASE, PTD_BASE, PTE_BASE }
/** Array initializer of GPIO peripheral base pointers */
#define GPIO_BASE_PTRS { PTA, PTB, PTC, PTD, PTE }
/* GPIO - Register instance definitions */
/* PTA */
#define GPIOA_PDOR GPIO_PDOR_REG(PTA)
#define GPIOA_PSOR GPIO_PSOR_REG(PTA)
#define GPIOA_PCOR GPIO_PCOR_REG(PTA)
#define GPIOA_PTOR GPIO_PTOR_REG(PTA)
#define GPIOA_PDIR GPIO_PDIR_REG(PTA)
#define GPIOA_PDDR GPIO_PDDR_REG(PTA)
/* PTB */
#define GPIOB_PDOR GPIO_PDOR_REG(PTB)
#define GPIOB_PSOR GPIO_PSOR_REG(PTB)
#define GPIOB_PCOR GPIO_PCOR_REG(PTB)
#define GPIOB_PTOR GPIO_PTOR_REG(PTB)
#define GPIOB_PDIR GPIO_PDIR_REG(PTB)
#define GPIOB_PDDR GPIO_PDDR_REG(PTB)
/* PTC */
#define GPIOC_PDOR GPIO_PDOR_REG(PTC)
#define GPIOC_PSOR GPIO_PSOR_REG(PTC)
#define GPIOC_PCOR GPIO_PCOR_REG(PTC)
#define GPIOC_PTOR GPIO_PTOR_REG(PTC)
#define GPIOC_PDIR GPIO_PDIR_REG(PTC)
#define GPIOC_PDDR GPIO_PDDR_REG(PTC)
/* PTD */
#define GPIOD_PDOR GPIO_PDOR_REG(PTD)
#define GPIOD_PSOR GPIO_PSOR_REG(PTD)
#define GPIOD_PCOR GPIO_PCOR_REG(PTD)
#define GPIOD_PTOR GPIO_PTOR_REG(PTD)
#define GPIOD_PDIR GPIO_PDIR_REG(PTD)
#define GPIOD_PDDR GPIO_PDDR_REG(PTD)
/* PTE */
#define GPIOE_PDOR GPIO_PDOR_REG(PTE)
#define GPIOE_PSOR GPIO_PSOR_REG(PTE)
#define GPIOE_PCOR GPIO_PCOR_REG(PTE)
#define GPIOE_PTOR GPIO_PTOR_REG(PTE)
#define GPIOE_PDIR GPIO_PDIR_REG(PTE)
#define GPIOE_PDDR GPIO_PDDR_REG(PTE)
*/ /* end of group GPIO_Peripheral_Access_Layer */
And in the MK10F12.h is so
-- GPIO Peripheral Access Layer
* @addtogroup GPIO_Peripheral_Access_Layer GPIO Peripheral Access Layer
typedef struct {
} GPIO_Type;
/** Peripheral PTF base address */
#define PTF_BASE (0x400FF140u)
/** Peripheral PTF base pointer */
#define PTF ((GPIO_Type *)PTF_BASE)
#define GPIO_BASES { PTA, PTB, PTC, PTD, PTE, PTF }
