Real 1D FFT implementations for the k64f?
Search instead for
benledesma
Hi folks,
  I'm looking for a simple FFT algorithm which will take in real one-dimensional arrays of size 2^n and output an array of frequency amplitudes. I am using a k64f board and a processor expert project through kinetis design studio.
  Currently I have attempted to implement the algorithm found in here. The first half of the code works as written, but I have had issues getting the second half to work. I have also found FFTW and KISS FFT, but am unsure that either may be used with my choice of compiler.
Thank you for your help,
Ben L
Hello Ben L,
- We can run FFT on K64 use KDS,  while I don't know whether it can run FFTW and KISS FFT,
I think it mainly depend on if  the memory of chip can enough .
- About the FFT , we provide CMSIS lib in KSDK, it includes FFT , there is a example as X.J.Rong
said : What is the most efficient way to perform bulk DMA transfers from the ADC on the K64?
About the SDK download and used , you can refer to here :
Introducing Kinetis SDK v2
TIC
