Odd new() exception - K22F KDS
次の代わりに検索
482件の閲覧回数
tharonhall
I am getting a rather odd __cxa_throw() exception using operator new() using KDS and a K22F. I saw, odd, because it happens on only maybe the second invocation of new(), and there is PLENTY of room on the heap.
Using the representative code below:
class_ptr1 = new Class("Class 1");
class_ptr2 = new Class("Class 2");
class_ptr1 is assigned the address 0x20000020
When the attempt to allocate the second class fires, I get the __cxa_throw() exception. Of course, this would typically mean I am out of memory, but I have TONS of space left in the heap, unless i am reading this wrong somehow and the space is allocated top to bottom and not bottom to top:
.heap           0x20000000     0x8000
                0x20000000                . = ALIGN (0x8)
                0x20000000                __end__ = .
                0x20000000                PROVIDE (end, .)
                0x20000000                __HeapBase = .
                0x20008000                . = (. + HEAP_SIZE)
Anyone else seen this? This triggered after I changed my OSA from Bare Metal to FreeRTOS, so something funny may have happened there.
This has stopped me in my tracks, so any help GREATLY appreciated. Thanks!
307件の閲覧回数
tharonhall
So it appears that FreeRTOS didn't pull back into the code as cleanly as I had hoped. I did some clean up and the trap went away. Know I am having other issues with FreeRTOS, which I did not see before. It makes me suspicious that some more things are not set up correctly.
Will look at a clean FreeRTOS build for reference and see if I can't find something that is amiss.
307件の閲覧回数
Carlos_Mendoza
Hi Tharon,
Is good to hear that the problem with the __cxa_throw() exception was fixed, please let us know if you you run into any other problem.
Carlos Mendoza
Technical Support Engineer
