Going from CW 10.6 to KDS
Search instead for
juanm
Hi! I have a simple program for a KL05 running on CW 10.6, I tried to use the same code in KDS but it seems that many definitions are missing from MKL05Z4.h. For example, this code compiles fine on CW:
#include "derivative.h" /* include peripheral declarations */   unsigned int i;   int main(void) {   SIM_SCGC5 = SIM_SCGC5_PORTA_MASK ; //Activo reloj PTA   PORTA_PCR10 = PORT_PCR_MUX(1) | PORT_PCR_DSE_MASK;   GPIOA_PDDR |= (1<<10); //PTA10 como salida     for(;;) {      GPIOA_PTOR=(1<<10); //Toggle PTA10   for (i=61000; i; i--);   }    return 0; }
In KDS I change the include to #include "MKL05Z4.h", but when I compile I get errors saying that SIM_SCGC5, PORTA_PCR10, GPIOA_PDDR and GPIOA_PTOR aren't defined.
I'm missing another include file? It's strange because those definitions are present on the KL25Z include but not on the KL05Z.
Thanks.
Hello juanm,
(1) When create bareboard project (without Processor Expert ) on KDS ,Yes,,some header of chips have not define the "SIM_SCGC5" ..... ,
I think we can refer to the header of CodeWarrior to use the header of KDS or define .
For example :
SIM->SCGC5 = SIM_SCGC5_PORTA_MASK ;
PORTA->PCR[10] = PORT_PCR_MUX(1) | PORT_PCR_DSE_MASK;
(2) When create a Processor Expert project on KDS , in the header file of  "MKL05Z4.h",  there have the definition of "SIM_SCGC5" ....." 。
Alice
juanm
Freescale is planning on fixing this problem?
Thanks for the reply!
