I tried to get the TWR-K40X256 going with the Kinetis Design Studio.
First I needed to make an Bootloader Update. Everything went fine. After that the Debugger was found.
After that I tried to flash with the following configuration
This failed with the an error.
Can anybody help me with this? I tried an Software Update. But it didn't work and I have no idea what is the problem.
Thanks a lot.
Dorothee
Hello Erich,
Thanks to you, I could solve this problem. There was another gdb in my PATH variable. Everything worked.
But when I started the application this morning again, I had another problem. The error message reads as follows
Error in final launch sequence
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Error creating process C:/Users/brunner-beo/workspace.kds/Testskd/Debug/Testskd.elf, (error 193).
Maybe you can help me again.
Hi Erich,
I think the direction is right. I looked but the gdb is not running, and it is not started anyway.
So I searched for ist. But in the path "C:\Freescale\KDS_v3\Toolchain\arm-none-eabi\bin" there is no arm-none-eabi-gdb.exe like your link has discribed.
Hi Dorothee,
maybe gdb is already running? see https://mcuoneclipse.com/2015/05/18/gdb-client-and-server-unlocking-gdb/
I hope this helps,
Erich
