Does Kinetis has a simulator?
Search instead for
BlueTower
Hi!
New to kinetis. Does kinetis Design Studio has a simulator like stepping through the code etc. ?
thanks
BlueTower
Does Codewarrior for K series mcu's provides simulation for the K64P144M120SF5RM which is a FRDM-K64F device?
BlackNight
Hi Alexandros,
CodeWarrior for MCU does not include a simulator for ARM. Options are the ones outlined in this thread. Keep in mind that even these similator are mostly core simulator and do not simulate the full device.
Erich
vignesh_vb_7
Hi Erich,
              Is there any simulator for kinetis, which can simulate the full device?
BlackNight
Hi Vignesh,
I'm aware of the following two:
The GNU ARM Eclipse QEMU
µTasker - Simulation examples
Erich
BlackNight
Hi Alexandros,
a simulator is not included in KDS. But there is QEMU which you could use, see The GNU ARM Eclipse QEMU .
I hope this helps,
Erich
BlueTower
Is  the uTasker also a simulator that I can use?
mjbcswitzerland
Specialist V
New Freedom FRDM-K64F board
There is pre-built simulator at that link which can be tried [it takes about 30..40s from clicking the download link to running a virtual FRDM-K64F with Ethernet, Web server, Telenet, SD card and USB (although Winpcap should be installed on the PC due to its DLL being needed - it is already there if Wireshark has been installed].
Mark
BlackNight
Hi Alexandros,
yes, that's another simulator you can use.
Erich
