Debugging an array of pointers to structures
620件の閲覧回数
michaelhuslig
I have an array of structure points which is working in my code (struct userst * user_ptr[MAXUSERS]).  What I want to do in debug is hover over the declaration to see what is there.  What I am getting now is just:
Expression                  Type                                              Value
user_ptr                       struct userst *[]                             [0]
Using the memory browser I can see I have entries, and my code sees them properly too.  It would be nice to see the pointers in debug, even better to see the structures.
This is KDS3.2 with the latest updates using a MK22FX512
5 返答(返信)
466件の閲覧回数
Hello ,
Could you please show your project to let's see your code in detail .
Then I can debug it on my side to check .
Alice
466件の閲覧回数
michaelhuslig
Alice,
I forgot to mention that I am using PE micro's Multilink Universal.  Is
this something to do with the gdb server?  How much of my project would
you need.  Wouldn't you need my custom board in order to see what I am
seeing?
Mike H.
466件の閲覧回数
BlackNight
Hi Michael,
which debug probe you are using should not be relevant.
I tried to reproduce your problem, but works for me:
I used the following:
#define MAXUSERS 3
typedef struct userst {
  int a;
} userst;
struct userst a, b, c;
struct userst* user_ptr[MAXUSERS];
What is really needed is a piece of code to reproduce what you see.
I hope this helps,
Erich
466件の閲覧回数
michaelhuslig
Erich,
My structures were a lot more complicated.  I ended up declaring
individual array pointers and assigning them the same values in the
array.  This way I was able to examine the selected structures I needed
in debug.
Mike H.
466件の閲覧回数
Hi  Michael,
I just want to know detail what information you want to see.
Usually we check variable on ''Expressions " view of KDS you also mentioned :
If you want to check variable when the program on board is running, you can refer to this thread :
Automatic Variable, Expression and Memory Display with GDB and Eclipse | MCU on Eclipse
Hope it helps
TIC
