Cannot enable the flash configuration in KDS2.0 with PEx
995件の閲覧回数
mayawatanabe
I made my project from "File --> New --> Kinetis Design Studio Project" and selected FRDM-K64F board with PEx. I wanted to enable the Flash cofiguration field (Cpu : Common settings --> Flash cofiguration) but I wasn't able to do it.. If I changed the CPU type to another and backed to VLL, the flash configuration field becomes enable... Why the Flash config is disabled at first? Any other way to enable the flash config?
Maya
6 返答(返信)
745件の閲覧回数
Hello Maya,
After you change CPU type, do nothing , then change to MK64FN1M0VLL12 , the "Flash configuration field" can enable.
Alice
745件の閲覧回数
mayawatanabe
Hello Alice,
Thank you for the reply. Is this a feature? or a bug (will fix in the future version)? I'm writting a training material and want to know that...
Maya
745件の閲覧回数
Hello Maya,
According your question i have create a SR on CRM , have you received the email of freescale  ?
Alice
745件の閲覧回数
mayawatanabe
Hello Alice,
Yes, I've received a SR email. Thank you for your support!
Maya
745件の閲覧回数
Hello Maya,
Please check the attachment , this is hot fix .
Alice
745件の閲覧回数
Hi Maya,
About this , i need ask Processor Expert team , and will tell you .ASAP when get the result.
Alice
