C Algorithm, Execution Time
次の代わりに検索
557件の閲覧回数
walter_gallegos
I'm working with a sliced algorithm, so I like to know the execution time of each slice.
Exist into KDS a tool to calculate the execution time of a C algorithm or process ?
タグ(3)
2 返答(返信)
210件の閲覧回数
BlackNight
Hi Walter,
I'm using the Segger SystemViewer (see https://mcuoneclipse.com/2015/11/16/segger-systemview-realtime-analysis-and-visualization-for-freert... ) for this kind of measurement. With
SEGGER_SYSVIEW_OnUserStart(id)
I can start a measurement point, and with
SEGGER_SYSVIEW_OnUserStop(id)
I have the corresponding end point. You can have multiple different IDs so you can measure different spans. Using the SystemViewer I get the exact timing. I hope you are using a Cortex-M4(F) core, then you get the number of cycles. Otherwise on an a M0+ (because it does not have a cycle counter in hardware) the timing is measured with the SysTick ticks.
I hope this helps,
Erich
210件の閲覧回数
walter_gallegos
Hi Erich
Thank for answer, Segger SystemViewer apparently do the task; unfortunately I'm using  a P&E pod. So, I don't have access to a J-Link.
I will place some assert to validate pre/post-conditions into the slices; is not the same but be warrant non overlapping working condition.
Walter
