I have an issue about building my project on KDS 3.0. Below is what happened:
1. I installed KDS3.0 to a new computer due to some work reason.
2. I check out the code from git.
3. Start build the project as i do usually but it throw error that says make*** [project.elf] Error 1
4. I ran different project and same thing happened. I decided to switch back to kds2.0
5. I uninstalled KDS3.0 and install KDS2.0. Import the project and build it. It succeed.
Therefore, here is what I wondered, is there any configuration that i have to do in order to run kds2.0 project
on KDS3.0?
Yaran
Solved! Go to Solution.
Hi Yaran,
What error have you received (Console view)?
Because KDS v3.0.0 is using the GNU ARM Embedded (launchpad) tools, you will need to migrate/change a linker setting. See Kinetis Design Studio: Migrating KDS V2.0.0 Projects to GNU Tools for ARM Embedded (Launchpad, KDS V... for details.
I hope this helps,
Erich
Hi Yaran,
I hope this helps,
Erich
