Problem programming Bootloader accessing MDM-AP
juanordonezcerezo
I receive the following error programming bootloader:
InitTarget()
Connect Under Reset
Communication error while accessing MDM-AP.
Connect Under Reset
InitTarget()
Connect Under Reset
Connect Under Reset
****** Error: InitTarget(): PCode returned with error code -1
I use this guide:
https://nxp.gitbook.io/hovergames/userguide/programming
