Can these tools be configured to run on Linux?
搜索替代
1,512 次查看
jtmiii
Lab notes alude to non-windows platform where in steps 11 and 12 they both start with "If on Windows,"...
Certainly, Git, Python, Tensorflow are all originally from *nix platforms, and there is MCUxpresso for Linux, but
packaging of eIQupdate as a .exe file means that a Linux install is either discouraged or difficult.
I ask this because I have been unable to get MCUxpresso to talk to either of my 1060 or 1064 EVK boards although both the OSX and Linux versions talk to them just fine...
Guidance?
1,296 次查看
jc_pacheco
Hi James,
The lab can definitely be run in Windows and Non-Windows platforms. Just keep in mind that in order to run the labs, you need to extract the "eIQ Update.exe" file from eIQ ML Software Clinic - Lab and Software Files, which is a Windows executable. This is because that is an installer that requires you to accept a license agreement.
If you already accepted the license for those files, you can copy the files into your Linux/Unix system and proceed with the labs.
-JC
1,297 次查看
jc_pacheco
Hi James,
-JC
