SIM_RSTSTS is 0x0000
955件の閲覧回数
Mike_d
I'm trying to track down a reset issue on a 56F8345. At first the SIM_RSTSTS register would show a COP reset but I can never hit a breakpoint in the COP isr.  After disabling the COP it continues to reset and now the SIM_RSTSTS is 0x0000 after a reset.  What could cause this kind of behavior?
-Mike
2 返答(返信)
699件の閲覧回数
marco76
We have a similar problem. Often our application based on 56F8345 resets and we find in the registry SIM_RSTSTS 0x0000.
I wanted to ask you if you're using the CANbus module? Because I have doubts that it may be the cause.
I also wanted to ask you if you have the watch dog enabled?
Marco
699件の閲覧回数
xiangjun_rong
Hi, Mike,
The COP module can not generate interrupt, it can only generate COP Reset.  you can not hit break point even if you set break point at the P:0x0002, it is debugger problem, that  is way you can not hit interrupt if you setting break point at P:0x0002. You can not hit interrupt if you set break point at interrupt vector table.
If the SIM_RSTSTS is 0x0000 , it means that Reset event does not happen.
Hope it can help you
Xiangjun rong
