CodeWarrior 11 live watch with DSC
2,383 次查看
syuhong
Good morning!
I'm using CodeWarrior 11 for the first time with the MC56F81000-EVK, I'm converting from a TI C2000 platform. How can I watch variables in real time in CodeWarrior 11? At present, I can only pause the Debug variables to update the Watch window. I used to be able to observe the changes of variable parameters in real time in the development of TI CCS. I would like to ask Master to guide this how to set CW 11 to observe variables in real time. thanks.
5 回复数
2,374 次查看
xiangjun_rong
Unfortunately, the CodeWarrior for MCU ver11.x has not the function to display the variable while the DSC is running, as you have seen, you have to set a break point, when the DSC stops at the break point, you can watch the variables.
But we provide a dedicated tools called Freemaster which can display the variable while the DSC is running, it can also display variable with a curve vs time. The Freemaster can communicate with DSC via uart port.
This is Freemaster tools link:
https://www.nxp.com/design/software/development-software/freemaster-run-time-debugging-tool:FREEMAST...
In the SDK package for MC56F81xxx, there is Freemaster example.
SDK package link:
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/mcuxpresso-s...
Hope it can help you
XiangJun Rong
2,333 次查看
syuhong
Now I am learning PFC using MC56F8xxxx, I didn't find the source code as follow link.
https://www.nxp.com/docs/en/application-note/AN12618.pdf
I need the source code of PFC to study it that I would appreciate it if you can provide the source code.
2,329 次查看
xiangjun_rong
The PFC code are developed by NXP solution team, pls contact NXP FAE or distributor FAE to apply for the PFC application code.
I am not the right person to open the code to pubic.
XiangJun Rong
2,370 次查看
syuhong
I use MC56F81000 EVK that I didn't connect FreeMaster 2.5. Is there a step by step guide for using FreeMaster with the MC56F81000 EVK?
2,362 次查看
syuhong
I can connect successfully that I change FreeMaster to SCI connection.
Thanks your help.
