Bootloader for MCF56F83763 VLH
Search instead for
fasihahmed
Any one have the source code of bootloader for MCF56F83763?
I am also interested in its 'processor expert' setup
mohammad_kamil
williamjiang2017‌ we have bootloader and PE for  this device?
xiangjun_rong
Hi, Fasih,
As a new feature, the MC56F83xxx has ROM bootloader, in other words, the bootloader code is integrated into on-chip ROM, but we do not provide the source code of the ROM bootloader, I am sorry for not helping you.
XiangJun Rong
fasihahmed
So does this mean if i want to make my own bootloader, I will have to flash it over the ROM bootloader or what? Do you have any documentation for this?
We have a custom bootloader made for MC56F82748 that we now want to port to MC56F83xxx .
What should be the steps I should take here? I know I have to use the PE but i dont have any reference code to do that because the LDD components are different.
xiangjun.rong
xiangjun_rong
Hi, Fasih,
Of course, you can pass the ROM bootloader and use your own bootloader.
When you develop your own bootloader, there is a file called flash_config.c
you can modify the NV_FOPT element as 0x3F in uint8_t _flash_config_field[] array, after power up, the ROM bootloader will be passed, the PC will point to P:0x00 and execute from reset vector P:0x00.
In this way, you can jump to your own bootloader from P:0x00, which is the same as that of MC56F827xx.
For detailed inf, pls refer to Chapter 6 ROM Bootloader in RM of MC56F83xxx
Hope it can help you
Xiangjun Rong
