56F84789 PWMB
56F84789 PWMB
804 次查看
saideliu
Hello. I have a question about 56F84789. When I use 56F84789,  I configure the bean PWMMC to generator PWMA and PWMB in Codewarrior. However, I can observe PWMA signal ,but I cannot find PWMB signal. If there are some differences between PWMA and PWMB.Thank you.
4 回复数
607 次查看
xiangjun_rong
Hi, Liu,
The main difference of PWMA and PWMB is that the PWMB does not support nano-edge placement feature, the PWMA module supports the nano-edge placement feature. For the other feature, they are the same.
If you still have issue, pls post your project so that we can have a review.
607 次查看
saideliu
Hi!Rong.
I add the project in the attachment. And I found that the register PWMB_FSTS0 =0x0800.
I think the bean that configures PWMB may have some mistakes, pls look at the project and find the cause or give a project that uses bean configures PWMB.
Hoping for your reply.
607 次查看
xiangjun_rong
I have checked the PE configuration, a lof items are not set. I help you set all the PE configuration, now it is okay.
You can check the PWMB signals from GPIOG0,GPIOG1,GPIOG2,GPIOG3 and GPIOE8 and GPIOE9 pins, if you have TWR-8400 board, you can test the pin4,6,21,22,23,24 of J503 connector.
I attach the project which is based on your project.
Xiangjun Rong
607 次查看
saideliu
Thank you for your help. According to the project you attached, I found that Fault channel is configured by no instead of yes. Then I changed the configuration, PWMB worked.Thank you again.
