'msh' on 'ltib-cf_nommu-20081215' can not execute 'rcS' ( neither any other script )
次の代わりに検索
2,977件の閲覧回数
osanz
This is a problem on custom board based on LOGICPD 5373EVB, with ltib-cf_nommu-20081215
BSP.
The 'msh' shell can not execute the rcS script ( neither any other script ). As soon as the booting proces
arrives to  'inittab' line "::sysinit:/etc/rc.d/rcS" it hangs up maybe up to 30 minutes, and finally prints
on console:
$ ./rcS start
out of string space
What does mean 'out of string space' ???
 But system is not set.
I have achieved to initialize the whole system by adding all need setups on inittab as:
console::sysinit:/bin/mount -n -t proc proc /proc
console::sysinit:/bin/mount -n -t sysfs sys /sys
console::sysinit:/sbin/ifconfig eth0 102.128........
console::sysinit:/bin/mount -a
instead of calling the rcS....
But i need to execute scripts on my application!!!
7 返答(返信)
639件の閲覧回数
Elias
Yes, I found the same problem these days, the kernel hangs about 30 minutes to complain
"input line is too long" and
"/proc/sys/vm/min_free_kbytes: cannot create
/proc/sys/vm/vfs_cache_pressure: cannot create"
but only when i use dBug(4d.1a.1e), if i use u-boot, the kernel just boot OK!
639件の閲覧回数
osanz
Hi Elias!
I think your information can be very usefull for me!!!
Unfortunatelly is not easy for us to change the bootloader to u-boot, because we use dBUG to setup some other hardware on our board.... but
Can you post ( or send me ) your linux start-up messages??, maybe there is some in kernel configuration that is not properly done via dBUG, maybe we are missing something on the kcl???
Thank you in advance;
Oscar.
639件の閲覧回数
Elias
Hi Oscar,
I found nothing special different between dBug startup message and U-boot's.
========================== dBug Start Message ================================
External Reset
ColdFire MCF532x on the M5329EVB
Firmware v4d.1a.1e (Built on Jul 28 2009 14:12:51)
Copyright 2006 Freescale Semiconductor, Inc.
Enter 'help' for help.
dBUG>
dBUG> show
        base: 16
        baud: 115200
    autoboot: Stop at prompt
      server: 192.168.1.150
      client: 192.168.1.145
     gateway: 192.168.1.1
     netmask: 255.255.255.0
    filename: image.bin
    filetype: Image
     ethaddr: 00:CF:53:29:CF:01
         kcl: rootfstype=romfs
dBUG> dn
Downloading Image 'image.bin' from 192.168.1.150
TFTP transfer completed
Read 8294400 bytes (16201 blocks)
dBUG> go
Linux version 2.6.26-uc0 (alex@alex) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-4
5) ) #9 Thu Jul 30 16:48:35 CST 2009
uClinux/COLDFIRE(m532x)
COLDFIRE port done by Greg Ungerer, gerg@snapgear.com
Flat model support (C) 1998,1999 Kenneth Albanowski, D. Jeff Dionne
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 8128
Kernel command line: rootfstype=romfs
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 24168k/32768k RAM, (1942k kernel code, 240k data)
Mount-cache hash table entries: 512
net_namespace: 192 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
usb: Host1 host (h1-fsls) registered
usb: DR gadget (dr-fsls) registered
JFFS2 version 2.2. (NAND) ?2001-2006 Red Hat, Inc.
msgmni has been set to 47
io scheduler noop registered
io scheduler cfq registered (default)
mcf_edma: Initialized successfully
ColdFire internal UART serial driver
ttyS0 at MMIO 0xfc060000 (irq = 90) is a ColdFire UART
console [ttyS0] enabled
ttyS1 at MMIO 0xfc064000 (irq = 91) is a ColdFire UART
ttyS2 at MMIO 0xfc068000 (irq = 92) is a ColdFire UART
brd: module loaded
loop: module loaded
nbd: registered device at major 43
FEC ENET Version 0.2
fec: PHY @ 0x1, ID 0x20005c90 -- DP83848
eth0: ethernet 00:cf:53:29:cf:01
Driver 'sd' needs updating - please use bus_type methods
uclinux[mtd]: RAM probe address=0x40241da8 size=0x5da000
Creating 1 MTD partitions on "RAM":
0x00000000-0x005da000 : "ROMfs"
uclinux[mtd]: set ROMfs to be root filesystem
NAND device: Manufacturer ID: 0x20, Chip ID: 0x73 (ST Micro NAND 16MiB 3,3V 8-bi
t)
Scanning device for bad blocks
Creating 1 MTD partitions on "NAND 16MiB 3,3V 8-bit":
0x00000000-0x01000000 : "M53xx flash partition 1"
SPI: Coldfire master initialized
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ads7843 spi1.1: touchscreen, irq 68
input: ADS7843 Touchscreen as /class/input/input0
mcf-rtc mcf-rtc: rtc core: registered mcf-rtc as rtc0
Real Time Clock Driver v0.1
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
mcf-rtc mcf-rtc: setting system clock to 1970-01-01 00:00:41 UTC (41)
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 68k freed (0x4021d000 - 0x4022d000)
init started: BusyBox v1.11.2 ()
starting pid 18, tty '': '/etc/rc.d/rcS'
eth0: status: link up, 100MBit Full Duplex, auto-negotiation complete.
...<AFTER ABOUT 20~30 MINS>...
input line too long
starting pid 19, tty '': '-/bin/sh'
BusyBox v1.11.2 () built-in shell (msh)
Enter 'help' for a list of built-in commands.
======================= U-boot Start Message  ==============================
U-Boot 2009.06-00438-gb86b85e ( 7?27 2009 - 10:33:47)
CPU:   Freescale MCF5329 (Mask:54 Version:2)
       CPU CLK 240 MHz BUS CLK 80 MHz
Board: Freescale FireEngine 5329 EVB
I2C:   ready
DRAM:  32 MB
FLASH:  2 MB
NAND:  16 MiB
Net:   FEC0
-> tftp 0x41000000 uImage
Using FEC0 device
TFTP from server 192.168.1.150; our IP address is 192.168.1.145
Filename 'uImage'.
Load address: 0x41000000
Loading: #################################################################
done
Bytes transferred = 3927924 (3bef74 hex)
-> bootm 0x41000000
## Booting kernel from Legacy Image at 41000000 ...
   Image Name:   Linux Kernel Image
   Created:      2009-07-31   5:14:51 UTC
   Image Type:   M68K Linux Kernel Image (gzip compressed)
   Data Size:    3927860 Bytes =  3.7 MB
   Load Address: 40020000
   Entry Point:  40020000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
TCP reno registered
brd: module loaded
loop: module loaded
eth0: ethernet 00:e0:0c:bc:e5:60
t)
mcf-rtc mcf-rtc: setting system clock to 1970-01-01 00:00:31 UTC (31)
Mounting /proc and /sys
Setting the hostname to freescale
Mounting filesystems
mount: mounting devpts on /dev/pts failed: No such device
Starting syslogd and klogd
Running sysctl
Setting up networking on loopback device:
Setting up networking on eth0:
eth0: config: auto-negotiation on, 100FDX, 100HDX, 10FDX, 10HDX.
starting pid 114, tty '': '-/bin/sh'
eth0: status: link down.
$ eth0: status: link up, 100MBit Full Duplex, auto-negotiation complete.
$ ps
  PID USER       VSZ STAT COMMAND
    1 root      1032 S    init
    2 root         0 SW<  [kthreadd]
    3 root         0 SW<  [ksoftirqd/0]
    4 root         0 SW<  [watchdog/0]
    5 root         0 SW<  [events/0]
    6 root         0 SW<  [khelper]
    7 root         0 SW<  [kblockd/0]
    8 root         0 SW<  [khubd]
    9 root         0 SW   [pdflush]
   10 root         0 SW   [pdflush]
   11 root         0 SW<  [kswapd0]
   12 root         0 SW<  [aio/0]
   13 root         0 SW<  [nfsiod]
   14 root         0 SW<  [mtdblockd]
   15 root         0 SW<  [spi_coldfire]
   16 root         0 SW<  [rpciod/0]
   77 root      1028 S    /sbin/syslogd
   79 root      1024 S    /sbin/klogd
   97 root      1060 S    udhcpc -i eth0
  114 root      1188 S    -/bin/sh
  130 root      1040 R    ps
$ cat /proc/filesystems
nodev   sysfs
nodev   rootfs
nodev   bdev
nodev   proc
nodev   sockfs
nodev   usbfs
nodev   pipefs
nodev   anon_inodefs
nodev   tmpfs
nodev   inotifyfs
nodev   ramfs
        msdos
        vfat
nodev   nfs
nodev   jffs2
        romfs
nodev   mqueue
nodev   rpc_pipefs
$ cat /proc/meminfo
MemTotal:        24236 kB
MemFree:         13532 kB
Buffers:           912 kB
Cached:           1240 kB
SwapCached:          0 kB
Active:           1076 kB
Inactive:         1044 kB
SwapTotal:           0 kB
SwapFree:            0 kB
Dirty:               0 kB
Writeback:           0 kB
AnonPages:           0 kB
Mapped:              0 kB
Slab:             8364 kB
SReclaimable:      220 kB
SUnreclaim:       8144 kB
PageTables:          0 kB
NFS_Unstable:        0 kB
Bounce:              0 kB
WritebackTmp:        0 kB
CommitLimit:     12116 kB
Committed_AS:        0 kB
VmallocTotal:        0 kB
VmallocUsed:         0 kB
VmallocChunk:        0 kB
639件の閲覧回数
obidon
I had that problem initially after moving to ltib-cf_nommu-20081215. My project is using the dBug bootloader and MCF5328 custom board based on the MCF5329EVB.  I never did pinpoint the problem, but it went away after disabling several things I didn't need that were defaults in the BSP. I am not using CAN, eDMA, rtc. I changed some of the USB options, some of the USB features I load as modules. I also changed some of the busybox options. If I get time I will try to reproduce this and find what specifically is causing it.
639件の閲覧回数
osanz
Hi! ( here we are after vacation)
Elias, thanks a lot for your reply, i will study carefully!!!
obidon, ok it seems there is some 'wrong setting' on ltib-cf_nommu-20081215. In fact we have disabled almost everything on our board but the USB too, but in our case all regarding USB is compiled in the kerenel not as module ( maybe the problem is on USB?? ). Thanks a lot really!!!
BR.
Oscar Sanz.
639件の閲覧回数
osanz
Hello again;
Really both boot traces are identical. Just one diference that is supposed to be booting 'independent';
uboot uses a compressed image and dBug a binary image.
Maybe booting binary image in uboot has the same result?
obidon, are you using binary or compressed image on your working board?
I'm going to test it on my board.
Oscar.
639件の閲覧回数
obidon
Sorry, I've been away. I am using a bin image and never did use a compressed image. I have 32M Spansion NOR on the board so no need for a compressed image.
