modulo_switch CLI
modulo_switch CLI
830 次查看
francois_boucha
I would like some feedback on the modulo_switch CLI program to gather statistics, that doesn't work.  Calling command "show statistics" returns nothing on the shell, so is it normal?
type:
# /usr/sbin/modelo_switch
Switch> show statistics
thanks,
Francois
735 次查看
francois_boucha
Just type in "disable" to the prompt and it'll be O.K.
4 回复数
735 次查看
francois_boucha
Hi, Also I would like to know how to disable the debugging strings outputting to the shell.
I'm continuously getting:
13:50:10 Switch> send error!, errno = -1
13:50:18:RX undef bpdu type=8
13:50:18:RX undef bpdu type=4
13:50:28:RX undef bpdu type=8
13:50:28:RX undef bpdu type=4
thx
736 次查看
francois_boucha
735 次查看
TomE
Specialist II
I have no idea what CPU, Development System or Operating System you're using. There may be a more appropriate forum for your post. Are you using Linux, MQX or what?
Tom
735 次查看
francois_boucha
It is the MCF54418, on Linux 2.6.29
I tried two versions of that (modelo_switch) program, but I don't know the version number, but I can differentiate them from the size they have:
-1st one was 92.6 kB;
-2nd one, size = 249.4 (Taken from M54418Tower_Linux_BSP_20110422_ltib.iso);
Both of the program mentioned above are doing the same thing.
Francois
Message was edited by: Francois Bouchard
