getting started with MCF52233
1,506件の閲覧回数
ridges
My name is Martin. I'm interesting in develop an application with MCF52233.
The application work's over tcp/ip network. I have some MCF52233 demo board. I'ud like to use then as client and the PC as server. My question is if there are any aplication note about this. I have the AN 3518. But i dont know if trere are any others application notes or information.
The project consist in read an tri axis accelerometer in demo board (client) and transmit to the PC (sever) over TCP/IP network. This projet is for the university.
well thanks to all and i'll waiting for your answer...
Martin
750件の閲覧回数
MCF52233
Hi martin,
u can check out the coldfire lite project which includes many options like udp client , tcp client,
tcp serial client,http server.Also check application note AN3507:stck calculation ,AN3455:http server
,AN3470:tcp/ip stack and RTOS.
2 返答(返信)
751件の閲覧回数
MCF52233
Hi martin,
750件の閲覧回数
ridges
Thank you very much for your recommendation. There is an example that is right for my application.
see you soon...
thanks again
Martin
