VLLSx on Coldefile+
Search instead for
VLLSx on Coldefile+
nz_developer
Trying to get a coldfire+ into VLLS3 mode but when I measure the current it is not dropping (3uA according to datasheet. I am at several mA.)
Any Ideas? I call the Sleep function to put into low power mode
void deepsleep (void)
/* Set the SLEEPDEEP bit to enable deep sleep mode (STOP) */
    asm (  stop #0x2000; );
void Sleep(void){
    u8 dummyread;
    SetAlarm(10); // wake up in 10 seconds
    SetLLWU(); // setup wakeup events
        SMC_PMPROT = SMC_PMPROT_AVLLS_MASK;
         SMC_PMCTRL &= ~SMC_PMCTRL_STOPM_MASK ;
         SMC_PMCTRL |= SMC_PMCTRL_STOPM(0x4) ;
         dummyread = SMC_PMCTRL_STOPM(0x4);
         SMC_VLLSCTRL =  BIT2;
        /*wait for write to complete to SMC before stopping core */
         dummyread = SMC_VLLSCTRL;
        dummyread = SMC_PMCTRL;
           deepsleep();
nz_developer
Found the problem, it was a register to enable stop mode had not been set right. Used Processor expert to setup and that solved it. Got 3uA draw and wake on timer or one of my 3 buttons, very nice.
Nouchi
Senior Contributor II
You have to take care about unused pins, they must be configured as output, or tied to vdd, because floating pin may draw current.
Emmanuel
nz_developer
Hi Thanks,
Can I just set to output low? some of my pins need to be low while in Sleep mode.
Thanks again
Nouchi
Yes but, if you have some pull-up on it, it will drawn current, so you have to take to disable internals pull-up and remove external if needed.
nz_developer
Tried lots of port configeration settings including disabling all ports etc. Got the current down to 360uA about 100x what I should be getting from the datasheet. Not too easy to solve, I will request support from Freescale through distributor.
Nouchi
You have maybe something still powered or clocked.
When you begin to play with micro amps, you have to hunt for leaks.
nz_developer
