New to TCP\IP need help....
1,542 次查看
satinderKhera
Hi All,
I am new to TCP\IP and want to develop a server application with MCF52259 i.e my board will be in listening mode and the communication will be initiated by a remote client. For developing this application I am using FNET stack for freescale. To develop my confidence I am trying to recieve a byte from remote client and send the same back to the client but I am unable to do it. I am pasting my test code, can someone help me and suggest if I am doing something wrong.
int main(void)
int   server_socket,client_socket;
unsigned int   data_length = 1;
int   data_length1 = 1;
unsigned int   RecvMsgSize=0;
char   TCPIPRxBuffer[256];
 struct sockaddr_in    server_address,client_address;
 /*creating a listening socket*/
 server_socket = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
 /*filling the relevant data */
fnet_memset(&server_address, 0, sizeof(server_address));
server_address.sin_family = AF_INET;
server_address.sin_addr.s_addr = INADDR_ANY;
server_address.sin_port = 1234;
 /*binding the socket address to the listening socket*/
 if((FNET_OK == bind(server_socket, (struct sockaddr *) &server_address,sizeof(server_address))))
 /*binding successful*/
 else
 fnet_printf("\nbinding error\n");
 if((FNET_OK == listen(server_socket, 10)))
            /*listening on socket*/
else
fnet_printf("\nlistening error\n");
    while (TRUE)
        /*waiting for a connection and accepting it*/
        data_length1 = sizeof(client_address);
        client_socket = accept(server_socket,(struct sockaddr *) &client_address,
        &data_length1);
        /*recieving from accepted connection*/
        if(FNET_OK == recv(client_socket,(char*)TCPIPRxBuffer,data_length1,0))
        send(client_socket, (char*)TCPIPRxBuffer, 256, 0);
        /*closing the socket*/
        if(FNET_OK == closesocket(client_socket))
        else
              fnet_printf("\nsocket closing error\n");
Please suggest whether I am missing something or doing something wrong.
Satinder Singh
787 次查看
butok
Hi Satinder Singh,
I see several issues in the code:
- the code is written by the way that accept(), recv() and send() are blocked. They are not blocked.
- the code does not check the accept() return value.
- the code checks recv() for FNET_OK. The recv() never returns FNET_OK: http://fnet.sourceforge.net/manual/group__fnet__socket_ga554ce7ef429f34cc322dff78061d60ab.html#ga554...
More info: http://fnet.sourceforge.net/manual/group__fnet__socket.html
To avoid most of the issues, as a reference for your server code you can use the sources provided with the FNET project, for example the HTTP, TELNET servers.
Andrey Butok
787 次查看
satinderKhera
Dear Sir,
I tried after implementing the changes suggested by you, but I am still unable to communictae through TCP\IP. I have done the changes as shown below:
        if((client_socket = accept(server_socket,(struct sockaddr *) &client_address,
        &data_length1))>0)
            if(FNET_OK == setsockopt(client_socket, SOL_SOCKET, SO_BLOCKING, (char*)&data_length1, sizeof(client_socket)))
                recv(client_socket,(char*)TCPIPRxBuffer,data_length1,0);
       closesocket(client_socket));
Please comment if i am still doing something wrong and suggest the correction.
Satinder Singh
787 次查看
satinderKhera
Dear Mr. Butok,
Thanks for your reply, from the issues raised by you I understand the following things:
I understand that I need to set the socket option to blocking mode for the client socket i.e.I need to add the following line in the code after calling accept( )
I need to chek the accept( ) success\failure
        &data_length1))>0)
this is required to be done.
this check is to be removed.
I will do the changes suggested by you and will get back to you after trying these changes.
Thanks & Regards,
Satinder Singh
