Math library for MCF5329
1,134 次查看
cktrod
We seem to be having speed problems doing floating point math on the MCF5329 using the Microtec compiler (Mentor Graphics Edge IDE).  Is there a free math library with source code provided by Freescale that I can compile with my code-base to compare performance?
Rod
623 次查看
sirlenzelot
Hi Rod,
I'm sorry, I can't help you with a free math lib. But I read that you are using EDGE IDE. Do you have problems with the development under EDGE, too? Maybe we can talk about EDGE? Do you know a good place where to discuss things about EDGE?
Dirk
623 次查看
cktrod
Dirk,
Don't get me started on Edge.  I notice that Mentor Graphics doesn't have a community set up on their forum to discuss edge.  Gee, I wonder why.
Too expensive
Slow loading
Slow debug stepping after a few debug cycles
Memory Leaks
Crashes just as you're getting close to the bug
Variables with unknow values
Variables with incorrect decoding
Intermittenly grayed-out memory window
But this probably isn't the place to discuss it.
Happily moving away from Edge,
Rod
