i am trying to run function from ram. When i try to compile the program I receive the error saying: "MyFunction in file main.c is referenced but has not been written. Check your linker command file."
the .lcf file looks like this:
# Sample Linker Command File for CodeWarrior for ColdFire MCF51QE32
# Memory ranges
MEMORY {
code (RX) : ORIGIN = 0x00000410, LENGTH = 0x00007BF0
userram (RWX) : ORIGIN = 0x00800000, LENGTH = 0x00002000
SECTIONS {
# Heap and Stack sizes definition
___heap_size = 0x0400;
___stack_size = 0x0400;
# MCF51QE32 Derivative Memory map definitions from linker command files:
# ___RAM_ADDRESS, ___RAM_SIZE, ___FLASH_ADDRESS, ___FLASH_SIZE linker
# symbols must be defined in the linker command file.
# 8 Kbytes Internal SRAM
___RAM_ADDRESS = 0x00800000;
___RAM_SIZE = 0x00002000;
# 32 KByte Internal Flash Memory
___FLASH_ADDRESS = 0x00000000;
___FLASH_SIZE = 0x00008000;
.userram : {} > userram
.code : {} > code
.text :
*(.text)
. = ALIGN (0x4);
*(.rodata)
. = ALIGN (0x4);
___ROM_AT = .;
___DATA_ROM = .;
} >> code
.data : AT(___ROM_AT)
___DATA_RAM = .;
. = ALIGN(0x4);
*(.exception)
. = ALIGN(0x4);
__exception_table_start__ = .;
EXCEPTION
__exception_table_end__ = .;
___sinit__ = .;
STATICINIT
__START_DATA = .;
*(.data)
. = ALIGN (0x4);
__END_DATA = .;
__START_SDATA = .;
*(.sdata)
. = ALIGN (0x4);
__END_SDATA = .;
___DATA_END = .;
__SDA_BASE = .;
. = ALIGN (0x4);
} >> userram
.copyToRAM: AT(___DATA_ROM + SIZEOF(.data))
. = ALIGN (0x4);
__START_COPYTORAM = .;
*(CopyToRAM)
__END_COPYTORAM = .;
} >> userram
.bss :
___BSS_START = .;
__START_SBSS = .;
*(.sbss)
. = ALIGN (0x4);
*(SCOMMON)
__END_SBSS = .;
__START_BSS = .;
*(.bss)
. = ALIGN (0x4);
*(COMMON)
__END_BSS = .;
___BSS_END = .;
. = ALIGN(0x4);
} >> userram
.custom :
___HEAP_START = .;
___heap_addr = ___HEAP_START;
___HEAP_END = ___HEAP_START + ___heap_size;
___SP_END = ___HEAP_END;
___SP_INIT = ___SP_END + ___stack_size;
. = ALIGN (0x4);
} >> userram
__SP_INIT = ___SP_INIT;
___SP_AFTER_RESET = __SP_INIT;
_romp_at = ___ROM_AT + SIZEOF(.data);
.romp : AT(_romp_at)
__S_romp = _romp_at;
WRITEW(___ROM_AT);
WRITEW(ADDR(.data));
WRITEW(SIZEOF(.data)+SIZEOF(.copyToRAM)); #size
WRITEW(0);
WRITEW(0);
WRITEW(0);
main.c file looks something like this:
#pragma CODE_SEG __FAR_SEG CopyToRAM
unsigned int MyFunction(unsigned int n) {
return n*3;
#pragma CODE_SEG DEFAULT
Then i call function from main.c like:
unsigned int reslt;
reslt=MyFunction(5);
Thanks.
Florijan
this pragma seems to not work:
I managed to make it working with CF2 method:
#pragma define_section CopyToRAM "CopyToRAM" far_code
__declspec (CopyToRAM) unsigned int Fibonacci(unsigned int n) {
/*Code here*/
return n*n;
And here's my lcf file:
# Sample Linker Command File for CodeWarrior for ColdFire MCF51QE128
# Memory ranges
MEMORY {
code (RX) : ORIGIN = 0x00000410, LENGTH = 0x0001FBF0
SECTIONS {
# MCF51QE128 Derivative Memory map definitions from linker command files:
# 128 KByte Internal Flash Memory
___FLASH_SIZE = 0x00020000;
.code : {} > code
.text :
*(.text)
. = ALIGN (0x4);
*(.rodata)
. = ALIGN (0x4);
___ROM_AT = .;
___DATA_ROM = .;
} >> code
___DATA_RAM = .;
. = ALIGN(0x4);
*(.exception)
. = ALIGN(0x4);
EXCEPTION
___sinit__ = .;
STATICINIT
__START_DATA = .;
*(.data)
. = ALIGN (0x4);
__END_DATA = .;
__START_SDATA = .;
*(.sdata)
. = ALIGN (0x4);
__END_SDATA = .;
___DATA_END = .;
__SDA_BASE = .;
. = ALIGN (0x4);
} >> userram
### copyToRAM mod
*(CopyToRAM)
. = ALIGN (0x4);
} >> userram
### /copyToRAM mod
.bss :
___BSS_START = .;
__START_SBSS = .;
*(.sbss)
. = ALIGN (0x4);
*(SCOMMON)
__END_SBSS = .;
__START_BSS = .;
*(.bss)
. = ALIGN (0x4);
*(COMMON)
__END_BSS = .;
___BSS_END = .;
. = ALIGN(0x4);
} >> userram
.custom :
___HEAP_START = .;
. = ALIGN (0x4);
} >> userram
### copyToRAM mod ----------------------\
_romp_at = ___ROM_AT + SIZEOF(.data) + SIZEOF(.copyToRAM);
WRITEW(___ROM_AT);
### copyToRAM mod --------\
WRITEW(SIZEOF(.data)+ SIZEOF(.copyToRAM)); #size
WRITEW(0);
WRITEW(0);
WRITEW(0);
Thank you for the response. I will study this response. It will take a few days.
Have a nice day!
Florijan
