52258 Coldfire: How do we detect RTC battery loss / Loss of time?
1,318件の閲覧回数
circuitMaker
I see in the MCF52258 / 59 Ref Manual that the real time clock registers only get "reset" once, if the power sourct (backup battery) is disconnected.  The Days, Hours, and Minutes values go to "??".  Is there a bit to test to see if the clock is invalid?
Thanks!
733件の閲覧回数
circuitMaker
I may have found something that will work.
The alarm hours & minutes register (ALRM_HM) does get cleared on power loss.  Since I am not using the alarm, I load it with a pre-defined value.  On boot, I check to see if that value is still there.  If not, the battery was removed.
If you know of a better method, please chime in!
Thanks!
733件の閲覧回数
ipa
I used this chip - and I wasn't able to clean this alarm register - after startup it has something on it.
Ipa
